Xb Build
RCDAD said:
I'll measure my chassis when I get home. Although, this number will vary according to tire size. When I said level, I just meant the Dogbone and CVD should be parallel to the ground. They obviously don't stay parallel as the suspension moves.
Sorry for the repetitive questions:
the Dogbones are fine
but How do i measure the CVDs being parallel?
is it by Pressing the car Downwards and then releasing to see at which level the suspension Auto-bounces back at? because you see if I move the car upwards or downwards in position, the susp is moving with it and just staying at the same position in which I last left the car at.. which is making me not able to know if they are leveled
My chassis is a between 2 and 2 1/4 inches off the ground running a 5b wheel and tire combo.
Thanks a lot for the input.
I guess I should put limiting cables as well.
where do the cables hold onto? same place of the bolt of the sway bar plastic?
Silent_chaos said:
Thanks a lot for the input.I guess I should put limiting cables as well.
Chaos look at my xb gas build post see if this helps you any! I posted all that I found last nite and nobody has even looked at it yet
I just used an empty hole on the shock tower and drilled a new hole next to the sway bar mount on the lower control arm.
Well, I found out this little screw on the suspension was the reason why the car was standing high. Fixed that up! Car is all Leveled now!Next and Final Stop: 7075RC Lower Suspension Arms! *waits desperately for Ol'fart
/monthly_2014_02/20140218_192800_resized.jpg.9e32d5f8f3b083669ee6f052efd6164e.jpg
/monthly_2014_02/20140218_193033_resized.jpg.fcba3406e4c98eebee486434bebfacef.jpg
Yep droop stop screw.
If there is a good amount of pressure from the springs and the screw is holding back the arm, the suspension arms will eventually warp.
