XB-E Spec confirmation for input into a Est Speed Calc
Gee
Could someone help verify these specs for me. BrianG at RCMonster.com has an cool web page with a bunch of useful info for brushless setup. One is the estimated speed calc.
R/C Calculations Link:
http://scriptasylum.com/rc_speed/index.html
Speed Calc Link:
http://scriptasylum.com/rc_speed/top_speed.html
Specs I gathered from the online XB-E manual but need verified:
Differentials
33t Ring Gear
11t pinion
(33/11) Diff Gear Ratio: 3
Spur & Pinion Gear (Manual has two pinions listed)
41t Spur Gear
10t Pinion
11t Pinion
LIPO Batteries & Voltage
(2) 11.1v 3s 3600mAh lipos
22.2v Total 6s Lipo Setup
Motor KV? XB-E listed two but I foung a seperate document for the motor B4485.
960kv Brushless Motor Specs seperate Documentation
1150kv XB-E Manual
1220kv XB-E Manual
Tire Diameter?
XB-E Buggy tire: 6"
PLine Excavator: 7"
I couldn't find a size anywhere for the buggy tires. I plugged the Proline Excavators size into the calc.
This is the output I got by plugging in the numbers bolded from above:
Differential Ratio: 3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 41
Pinion Tooth Count: 11
Total Voltage: 22.2
Motor KV: 960
Tire Diameter (inches): 7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.73 : 1
Total Ratio: 11.18182 : 1
Tire Circumference (inches): 21.99 inches (558.58 mm)
Rollout: 1.97:1
Total Motor Speed: 21312 RPM
Vehicle Speed: 39.69 mph (63.76 km/h)
Effective KV Value: 960
KT constant: 1.41 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
You are a math wizard good sir!
Just uploaded video with some radar speed runs.
I tested this same vehicle before and it was a few MPH faster but I will stick with your math and these latest runs as the stock top speed.
[ame]
[/ame]
Darin
Thanks for the video and the comment but BrianG is the real math wizard. Do you know the diameter of the stock tire for hte XB-E? Also, do I have the pinion size right at 11t?
Love the vid Darin! :D
The tires are 6" in diameter...so by the speed calc at max voltage of the fresh packs (4.2v/cell) top speed should be 38mph, pretty dang close eh? At 3.7 volts/cell top speed drops to around 34mph and around 3.2v/cell (my lipo minimum) top speed drops to around 30mph. The speed calc is definitely worth bookmarking, ive used it for quite some time.
Here is my results at 4.2v/cell with fresh lipo packs off the charger:
Other Ratio: 1
Total Voltage: 25.20
Motor KV: 960
Tire Diameter (inches): 6
Tire Circumference (inches): 18.85 inches (478.78 mm)
Rollout: 1.69:1
Total Motor Speed: 24192 RPM
Vehicle Speed: 38.62 mph (62.03 km/h)
Thanks Obeast! I added to my first post to show the buggy tire. Good point on the fresh lipo charge. I am pulling the plug and ordering up a XB-E as we speak. The 5b is going up for sale soon! I already ordered some more lipos to go with the pile of 3s lipo I already have. Picked up a couple of 6s 5000mah 30c today.
Acckk! That means only 29 left!!!!!! Crap I wish the USPS would pay me the damn money they owe me already so I can get one! In all seriousness, grats! :D
