xb gearing
andyken
New Hampshire
I seem to have good low end power, but want more top end speed.
What can I do for more top end? I have a 30cc with a jet pro pipe...stock everything.
+1
Also you will want to invest in some wheel adapters. You then can run the Baja wheels/tires. They are a little larger in diameter which will also give you a bit more top end speed.
Deluge said:
Hmmm. That's an odd place to put bearings. If they're missing, just buy the bearings. They're 8x16x5's.
Right now the square part the gears fit to just spins on the shaft...?
The manual showed bearings in the sqare part.
I ordered a new one with bearings
