XB Shock Oil Weights
I put an extra o-ring at the bottom of the shocks and I'm using 20 wt fork oil as in the hpi Baja. leaking is almost non existing and stays very stable when the shocks get hot, ooo and I also run at the same track as demon.
Thanks guys, I'll have to go through my shock oils and see what different weights I have. Figured since I was going to tear down my XB before I ran it, I might as well refill the shocks too.
Nobody really knows what weight it is or even what it is. Redcat does not have that info.
I'm going to say somewhere around 50cc for the X-series shocks. I know a 60cc bottle of fluid is more than enough.
Awesome to know because I ordered 100cc of 40wt from ddm and was not sure how much I needed to do the job . Hell I may as well de anodize the caps and body's while I have them apart
It might be a little stiff. Even more so when it's cold. Give it a run and see how it drives. Part of the fun is experimenting with different setups.
