XB shocks
mrmopar1
Junior Member
Are the Redcat 710015 and 710016 upgrades? Aluminum body shocks. If not what do you suggest I use? I broke a front factory shock on second tank after hitting a small dirt mound for a jump. Thanx
Those are just the Resi version of the x-series shock. They are not any tougher, they hold more shock fluid to help keep the fluid temp stable. The MT shocks would be an upgrade.
That would be the 050019 and 050020 Aluminum shocks for the MT with the little upper reservoir? Just wanna make sure I order correctly. Thank You
The 50002N & 50003N are the MT shocks. The shocks you listed are the MT Resi shocks they will also work.
They look cool. In theory they are better because they hold more fluid which helps to keep the fluid temp down. I have a set and I can't tell any difference. I don't race, just bash. Like I said they do look cool. :) The reason I bought mine was because they were not blue. I bought mine for an XB and didn't want to deanodize a new set of shocks.
The Resis do take a larger bolt, so you have to drill out the shock towers a little.
I found a web page with some basic information on reservoir shocks:
http://www.atvsuspensiontech.com/reservoirs.htm
my interpretation of this in an rc context is:
considering that most rc's are traction limited the reduced mass of the basic shocks may improve the agility of the car, whereas the reservoir shocks could improve handling on bumpy terrain like cobblestones, pebbles, rocks
by virtue of it's increased volume of fluid and gas making the shock more plush without
sacrificing overall damping
they may be a significant upgrade specifically for the two stroke cars that constantly transfer vibration to the suspension system and counter the effects of that warming it up, creating wear and reducing overall traction
for the electrics:
honestly they seem only situationally useful and they increase the total mass and sprung mass of the car which would seem to make them a tuning option rather than a straight upgrade
from a purely practical point of view, money is probably better spent on tires, steering and power upgrades before worrying about total oil volume
however, they do look cool and may come in handy tackling extremely rough terrain
bare in mind, that's my opinion and not any kind of empirical fact
if anyone has them do tell, i'd like to know if there's a noticeable difference
over stock on any specific terrain types and i'll keep a note of it
XB shocks
You can run them stock and be ok. Later you can install threshold umbrella seals and they will probably never leak again. Might want to eventually replace the stock shafts with aftermarket ones. Just make dilute you get the newer stockers with 6mm shafts. Most out there now are the 6mm though
