I have an XB and run a 35 x 25 x 25 x 25 gear set in the transmission. Two of my 25 tooth gears were damaged and had to be replace. They are the square drive gears but I notice they are not identical. One has wider teeth, an extra rim on the topside, and no rim on the inside were you insert the square drive. The other 25 tooth gear has a rim on the inside where the square drive is inserted, the teeth are narrow, and it has one instead of two rims on the top side. I am fairly sure the one with the narrow teeth is part# 5016 and I had an extra. I am trying the find the part number for the one with the wider teeth and where I may purchase a replacement. I see DDM sells the set of three which includes both types but it is $54. I was hoping I could purchase the single 25 tooth gear with wider death for a lot less, like $16. I know this is confusing but I did the best I can. Any help is appreciated. Thanks
