xb troubleshooting- won't start, HELP!
kmatias
Junior Member
New to the hobby, trying to get used to my xb gas rc.
Won't start now??? Can you give me your top 5 troublshooting tips?
Would you... check/replace spark plug? Change out the gas? Other??? What are the top troubleshooting steps for "won't start"?
I don't think its flooded, i checked.
Thanks.
Vent the gas tank,set your needles to 1 1/4 for low speed,1 1/2 for high speed.Mix your gas 5.12 oz of oil to 1 gallon of gas = 25:1. don't choke it.Get a kill switch,killer bee being the best.Make shure your coil is tight(the bolts)check to make shure your getting spark.Hope this helps.
Not starting of a new car most of the time is because of:
1-vapor lock. You will need to vent the fuel cap or tank.
2-flooded. You should not have to choke a warm engine.
3-incorrect carb settings. Should be 1 1/4 out L and 1 1/2 out H
4-plug the cheap plug that comes with the car can just go bad. Check to see if fouled.
5-correct fuel mixture. Should be 25 parts fuel to 1 part 2 stroke oil.
Thanks, keep em' coming folks. :D
So, getting a new plug is a decent idea? I guess these things aren't bullet-proof/eternal?
Vent the gas tank... what exactly does that mean/look like? Thanks. :confused:
It's always a good idea to have spare parts on hand spark plugs being one for sure.
The little hole in the gas cap plugs up. You can either add a vent tube to the cap or directly into the tank. I did mine into the tank. The 3rd line is to vent the tank.
kmatias said:
Thanks, keep em' coming folks. :D So, getting a new plug is a decent idea? I guess these things aren't bullet-proof/eternal?
whats a decent replacement plug ?
