XB TT hybrid
GTi_Leo
so I'm looking to build a hybrid out of my XB. I'm looking to used as much as I can from my XB (control arms, diffs and powertrain, etc) but using MT/TT diff housings and chassis. i'll probably end up getting a TT rear wing set if I can.
curious to know if the XB control arms would work with the diff housing and shock towers from the MT/TT, will the control arm mounts bolt up to the diff housings as well as the upper control arm, will it work with the front shock tower and brace?
the rear is very much the same . the XB is wider at the box and wider at bearing carrier.
the front is not swap friendly at all at the wheel. not sure at the box
the top arms mounts totally different on rear.
i have swap on mt rears between XB 7075rc bearing carriers and box.
will MT/TT rear wheel hubs fit on the X series rear arms? the aluminum ones redcat sells looks pretty similar to the one 7075RC makes
