XB with Hostile AT's
csp1971
Missouri
Since I run mostly on grass and a bit of dirt, I figured since I own 4 pairs of Hostile AT's, I'll just put those on to see how they look. (the Ramtech-RC adapters worked great!).
I have one of those sets that are Hostile AT fronts, but the other 3 are the rears. So, I put rears on all around.
The wheel/tire weight each is 1 lb 8oz for the Hostile AT's, and 9.4 oz for the XB wheel/tire.
So I'm basically adding quite a bit of weight.
The front Hostile AT's are 14.4 oz each, but those are with the regular plastic beadlocks and the front HPI foams (the crappy foam).
If I put front AT's on all the way around, would I need some better foams than the HPI stuff? Thoughts?
LightForce said:
If you wont jump you will be fine,otherwise rear bearings and carriers will break down fast.
Kinda what I was thinking. I'll put the fronts on all the way around.
Again ,a nice job,the jet pro looks good.I just ordered a jet pro this morning, a black one.Dino told me to keep it oiled.Well guy`s ,you alway`s have me playing catch up.
