bigfol
This my xbe with a castle XL esc and a Leopard 1090kv motor, running 6s at the moment, down loaded data from the esc today spec as follows- max amp pull was a 180amps,3830 watts at 50662rpm. The max amps the motor is rated at is 160amps,so its a little high at the peak,the motor temp got to 77deg C. I was running a 15 pinion and 44 spur at the time of the data being taken, does anyone know if I run 8s will the amp draw come down?
