xbe shocks
Knuckles
Warren NJ
What are the lengths of the front and rear shocks for the xbe? Will the baja shocks fit on xbe? If so the fronts or rears?
Will Big Bore shocks fit on Xbe perfectly or will I have to do some retrofitting? Anyone try these, if so let's see some pics, thanks.
P.S. what about Nutech?
You will have to use different hardware. NBD. Other than that, they'll fit. You will need all fronts (Baja shocks). They are longer but still work fine.
NBD? Can you specify what type of hardware? Are they good quality? Any other options?
You will most likely need a different size bolt and nut for mounting the shock to the shock tower. I recommend the RC Screwz kit. It's great to always have what need.
