XBE Spur gear sloppy on the shaft
GRIPNRIP123
Northeast Oklahoma
I purchased a new spur gear that came with a new shaft. The gear was very a very loose fit to the shaft. The problem might be a result of some unfavorable stack tolerance? Either way I shimmed it tighter with a 2mm shim under the collar that holds the spur to the shaft. I only took some of the play out, I can see a little slop being beneficial.
Has anybody else had this issue?
What did you do to correct it?
Do any of you use loctite to hold bearings into the spur mounts?
Thanks guys!
Looking forward to your thoughts.
GRIPNRIP123 said:
I purchased a new spur gear that came with a new shaft. The gear was very a very loose fit to the shaft. The problem might be a result of some unfavorable stack tolerance? Either way I shimmed it tighter with a 2mm shim under the collar that holds the spur to the shaft. I only took some of the play out, I can see a little slop being beneficial. Has anybody else had this issue?
Thanks guys!
Do you mean the gear is too thin or the hole in the middle is too big??
