karlt
Stripped the gears in 60 seconds !!
Will a set of fg Marder steel gears fit instead ?
Cheers
Karl
Cheers
Karl
look here i'm sure this guy will help you http://www.gotpetrol.net/steel-gears-vt4838.htmlNo luck yet sorry. Ill try and find it later this week. Its mon sons bday tomo so I wont have a chance to look for it until Wed at the earlierst.
Did have metal pinion and plastic spur, even if plastic spurs are cheaper its not much use if they only last 60 seconds !
Has anybody seen a thread from a guy that put a pair of tie rod ends on the end of the shafts to keep them for separating ? got a link ?
was going to try something similar with a alu block and some proper bearings, maybe then plastic will do.
