xrc2 shell
haven't made one but sprayed it silver primer, ground the old 2 coats of paint of with my dremmel then pound shop primer, looks good
yea in the middle of 1 getting made, get hold of a shuttle pc outer case and go from there 2 hours and it should have it done if u got all the tools to do the job, or if ur not that fussey the base plate from a leckky cooker if it got a groove on it use it as a top plate from the air filter to the rear wing, if u get hold of an old drum from a washing machine & some half inch flat bar make ur self some real kool mud guards, or if u wanted some checker plate cut ur self an new base plate make it lighter 4 a bit more speed,1 rule keep it simpull
that what you call thinking outside the box, you guy's should post some pictures of the build and the finish
hows the pc shell coming long mate?
