XT front left wheel locked up. Need parts
Neff
Needs to be a chassis section on this forum...
Well, enjoyed the XT for another 20 min the other day before the left front wheel locked up. After taking it apart just now, looks like the left front driveshaft pin through the shaft itself somehow locked up inside the cup, thus breaking the cup. Any known problems with these?
Appears I need the left front knuckle assy, (plastic messed up) left front driveshaft, and driveshaft cup?axle assy. The differintial side is fine, the knuckle side is what got messed up
not sure how this happened as I was just driving up and down the street, no donuts etc... just noticed it not driving on that corner like it should.
Best place to get parts? I'm not sure if any kind of warranty could fix it.
If anyone has spare parts laying around, let me know as I'd like to get it fixed soon. I'll also post in the wanted Section
PS, Whats the best way to take these axle wheel adapters off? Set screws are out and still cant spin it off
The pin in the CVD gets loose and works its way over and hits the steel insert on the hub and locks up or breaks poop in the process.
Been there. Open up the manual, you'll see all the required parts in an exploded view. you can also google the manual online. If you can post a pic of the broken plastic that will help a lot.
Stock parts can be found in the redcat shop online. You can access there by just clicking on the advertisers on the left of the page.
if you want to consider upgrading it check 7075rc for 7075 T6 Aluminum.
As for the pin getting loose, it locks the wheel and it just doesn't spin. If you don't notice it, ull end up breaking other poop.
Best way is to red loctite that motherfuc*er lol.
Guys here will tell you to use the blue loctite. For me even the red sometimes gets loose. To each his own.
It is caused by the vibration of the 2 stroke motor.
Same kind of loosening happens in real cars which run a super sound system with heavy bass.
Noted... I'll start looking up what I need for parts. As off now, the plastic parts look like a part number
07117 caster block
07127 spindle
And theses wheel adapters? Both set screws are out. Shouldn't it just spin off the axle now. Doesn't seem to want to...
I didnt delve into it much yet. Just pulled the knuckle off. Not home now, but I'll check it out more tonight. I'll let you know. Thanks
I just learned you can buy a pair of the REAR Dogbones and run them in the front. That way you won't have to worry about that pin backing out and breaking other parts. I'm actually installing the rear dog bones on the front of my dads XT today.
This. Use red. Grind a spot into the pin as mentioned as well.
Iv read this but also seen that it causes binding. Let us know how it works.
chapinb said:
This. Use red. Grind a spot into the pin as mentioned as well.Iv read this but also seen that it causes binding. Let us know how it works.
Ya so turns out on the X-series you can NOT run the rear dog bones in the front. The axle cup does in fact hit the hub carrier.
