XT hex adapters
B2dmadmax
The last thread I saw about this was two years ago. I need a set of 24 mm hex adapters for my XT so I can run different Wheels like other threads have said they're just not anywhere to be found any suggestions thank you.
It's been awhile ago but I did see some online that those 24mm hex adapters were sold. Do a Google search and see what you can find.
i used baja rear hubs then got a some aluminum tubing (12mm O.D. 10mm I.D.) from amazon cut it down to the length i needed and drilled out the hole for the pin.
