Rob, Are you saying that the XT wheels will fit the MT?RampageHopUps said:The XT wheels are not in stock yet, but should be on Monday or Tuesday. The are a direct fit.
Okay....I thought the XT used the same square drive as the XB and I know our MTs uses a 23mm stock or 24mm Baja upgrade hex.RampageHopUps said:I think they are. I always switch to Baja rims right away, so I don't have any in the garage. They should be though.
I thought the MT are 22mm?Zapped said:Okay....I thought the XT used the same square drive as the XB and I know our MTs uses a 23mm stock or 24mm Baja upgrade hex.
