Yet another brake adjustment ???
Top Jimmy
Selkirk,NY
I am adjusting my brakes because the brake engages, but the truck keeps rolling. I've adjusted the grub screws on the back of the mount. What else allows the wheels to keep turning even thought the gears stop moving? any pics of the adjustment??? This is for my XT.
Thanks In Advance!!!
So, when you hit the brakes, the gears on the gear plate lock up? Check your brake square. Make sure the set screws are tight, and make sure it's not stripped out.
