It's lean... Hear how the motor sounds flat and bland. That is the sound of lean. Easiest way to tell was the bog when you hit the throttle.
Back the ls needle out 1/8 and I bet it will be dead nuts. but before you do that...
The easiest way to adjust that, is to back the ls needle out while the motor is warm and running, keep backing the needle out until the motor starts to have a "POPPY" "Raspy" sound and the rpm will increase. Keep backing it out until the idle stats you slow. Take note of where the needle is at this point.
Then turn the ls needle back in, the rpm will start to increase then it will start to drop, as soon as it starts to drop again go back the other way half the distance that you turned previously. Keep going back and forth until the idle rpm is the highest. )You are only going to be turning 1/8 to 1/4 turn at maximum.)
Once the rpm is the highest... Back the ls needle 1/16 turn anti clockwise and you should be set.
Now set or idle stop (silver screw) to the idle that you like and your done.
Does this make sence to you?
