v8davep
Hi, Just looking for some advice please, i have a Zenoah 260 in my recently aquired stadium truck, it was not very well maintained before i got it, the head was clogged with grass so may have been overheated.
After i stripped and rebuilt the engine / fitted a new piston ring it runs strong with no issues, but leaks oil from the front of the engine head / case gasket, is this usual as it had signs of a lot of oil all over it before i stripped it.
When i reassembled it the joint was very clean, i did not use any liquid gasket on the base gasket ...was not sure if i should have to?
Also i did not re torque the head bolts after running the ring in any ideas how to stop it leaking would be appreciated, runs fine just messy after a few runs.
