Zenoah 27cc
All the motors are set up the same. The R/C manufactures make there motor mounts fit he standard motors set up. So no, you will be ok in the event you buy a new one.;)
what about changing gears do u need to mod the engine?
No, the gears on the side will be matched. The gear that fit on the lay shaft that drives the diff will push the motor forward when changed to a larger one. This will be fine since the motor mounts move.
