Zenoah G290 will not bolt up to side engine mount
Xound5OH
Hi guys,
I'm having a problem with mounting a brand new Zenoah G290 motor to my Rovan baja. The motor is sitting higher then the stock Rovan 30.5cc motor did and the bolt that goes into the bottom of the chassis into the clutch housing is going into a different engine mount hole. I have attached a picture of the motor so you can see what I am talking about. I was under the impression that this would be a direct bolt in, any one have any suggestions?
Thanks,
Alex
Hi guys,
Thanks,
Alex
You need to use your old fan cover.
