Am currently in the process of picking up the bits and pieces required for the new HPI Baja build kit and am trying to do as much research as possible ahead of building/running the kit
Have opted for the G320RC engine and had picked up some Putoline MX5 fully synthetic oil to run it with. I was, however, recently advised by a fellow hobbyist that 2 stroke engines should be broken in using a mineral oil and not fully synthetic.
I have tried to research further on this, but the Zenoah manual just specifies oil grades and does not contain any information on the requirements for engine break in.
I did watch the video produced by OBR on engine break in and noted that they recommend Maxima Castor 927. I have read that some people use this oil for the first few tanks and then switch to a fully synthetic oil, as they burn cleaner.
I appreciate it is likely to be a minefield of opinions on such a topic, but was just looking to try and get some advice as to whether it is viable to run on fully synthetic from the get go or if there is a more recommended approach to take ?
Any advice would be much appreciated.
Thank you in advance
