benckie
The Zynit 4WD uses the same all wheel drive platform as the very successful Buggy Crypton 4WD.
To handle the higher forces in the drive shaft and suspension due to the massive Truggy wheels, the Zynit 4WD is already equipped with the following tuning parts:
- lower wishbone "minimum flex" (HF0032)
- axle with extended cup (HA0060) at the front suspension
- heavy duty spiral bevel gear at the differential (HD0014A & HD0015A)
- differential box made of reinforced composite-plastic
- extended cup at the differential output (HA0066)
- strong servosaver spring (HS0009C)
A short overview of the technical highlights:
- unique ext-trac® all wheel drive system
- extremely tough chassis- and suspension layout
- drive system: hardened and weight optimized metal gears with sealed gear boxes
- drive shaft power transmission
- alloy differential incl. spiral bevel gear
- double wishbone suspension with maximum setup variability
- large suspension travel
- runs exclusively on ball bearings
- adjustable alloy shock absorber incl. progressive springs
- powerful dual disc brake
- adjustable alloy servo saver
- easy access to change the gear ratio
- 26cc Zenoah engine (power output: 2,2KW / 3,0PS)
- factory assembled
length: 820mm
width: 550mm
height: 325mm
wheelbase: (variable) from 558mm (standard) to 526mm
weight: (without RC) approx. 14,5kg
tyre: diameter: 206mm, width: 93mm
camber: front- and rear axle adjustable
toe: front- and rear axle adjustable
fuel tank capacity: 650ml
gear ratio: variable in 10 steps
engine: Zenoah 26 cc - power output: 2,2KW (3PS)
Video
HURRAX 1/5 4WD Truggy Prototype Testing
