That’s the truth. It’s going to be one of my next. That would be an advantageous thing to do.Tbh it's not about brand but size of said lìpos....?....i run turnigy blues....turnigy nanotecs....or zippys.....?....u need to obv buy lipos what fit in the boxes on the sbr?
I appreciate the offer jimbo1 I think that I can take it from here. I’ve got a couple of weeks until payday so I don’t mind to look ?!!First off are you wanting to run 8s?
I don’t own the sbr but from what I can find Out is you can use x2 reaction 3s lipos so this gives a total size once you stack two together of
So if you can find 4s packs with these dimensions should work fine.
- Length: 5.47 in (139mm)
- Width: 1.85 in (47mm)
- Height: 2.75 in (70mm) 35mm each
As I don’t own the sbr yet you will know if there is any more room length,width or height wise as some soft case larger mah lipos can be longer.
For instance my traxxas udr fits standard racing size 4s hard case lipos perfectly but it still has 2+ inches left length ways.
Hope this helps ?
If you can get dimensions of the battery compartment I will happily help try and find some lipos bud?
And to answer the original question yes I would like to run 8s. Since I’m hopefully getting a UDR in the future I should get two 4s Lipos that’ll fit in both.First off are you wanting to run 8s?
Hope this helps ?
Off topic..but did u still want this darksoul duel servo mount??....First off are you wanting to run 8s?
Hope this helps ?
That was aimed at jimbo?I’ve got a Hot Racing servo mount that I just put in a couple of months ago. I appreciate it though!
Yeah i did see...?.no.worries ?..ebay it is then?thanks evssv. But I went a different way in the end ?
I think the super rock Ray has a larger compartment. I have a Super baja ray 1.0 and I can't find and 4s batteries that will fit. The Super Rock Ray has a bottom access door that adds room.as I was searching... out of eBay spare part offer
OS251080 Losi Battery Tray for Super Rock Rey
Genuine Losi spare/option part.
internal dimensions:
Lengh: 152mm
Width: 52mm
High: 105mm
