Obr 34 ss vs esp 34 vs Taylor 35 or do I go big bore?!?!
Crazybajabuild
Madawaska,ME U.S.A
Hey guys im building a Baja and i want it to be the baddest Baja I ever built so I wanted to go big bore, but I think it’s a lot of money for how much im gonna use it so what are peoples thoughts on these 3 other engines? I have an esp race ported 32 atm and it’s all fun and all but I think I need more. Any help would be awesome
I thought about it but someone said it’s more complex with having to tune two engines
yeh its more complex but not massively mate (y),
reaally all you need to do is run the cylinders within 10 degrees celcius of each other, fit a pair of tto temp sensors and run at idle, add a tad more fuel to the hotter running cylinder till you get roughly within 10 degrees, run the car and do the same with the high end needle,
once its there leave it alone unless it creeps high temp on one top end, repeat as you need to,
i did the above on my twin and got 40 to 50 tanks i think it was before needed a re ring,
am just in process of a full rebuild now 6 years after owning the engine ,
very important to keep carb butterflys in sync as well, they wont need sorting from new if you go obr, but simple enough to do if you renew carbs at any time etc,
Either it’s the baddest Baja or it’s not. Go big bore or regret it forever. Detroit performance will let you buy the engine pay it off as you go and then send it to you when your doing paying for it
Like layaway?
Let’s just say I do go the twin route lol.. would u suggest going with the obr setup or Detroit?
