best bet is send mike taylor an email and explain the situation fella, he is really helpful, send him a couple of pics etc and i'm sure he will get you sorted out ,I understand what you’re saying . Because I have one on my Bartalone pipe . But this pipe when installed , you only get a space the thickness of a credit card . I would have to practically bent the pipe for it to fit .
Thank you so much and happy holidays to you .best bet is send mike taylor an email and explain the situation fella, he is really helpful, send him a couple of pics etc and i'm sure he will get you sorted out ,
the contact email is on the taylor site, he usually replies quickly but give hime a day or so cos sometimes he gets very busy,
yep yer right ryan, i may have linked the wrong one, i'll link the baja tsk one below but theres no clear pic of the mount at front of the pipe,Hey Paul, the pics on Taylor's website is of the pipe mounted on a hybrid and the pipe bracket is on the throttle servo
A bit strange really, I saw the pipe you linked but figured the mounting was different to fit the tsk cage. Honestly in his situation I'd just hard mount it if it was me but in his case I'd find some heat resistant rubber and stick it in there. It just looks like that pipe was ment to fit a hybridyep yer right ryan, i may have linked the wrong one, i'll link the baja tsk one below but theres no clear pic of the mount at front of the pipe,
although it does come with a bobbin as well ,
https://www.taylorrc.co.uk/product-page/taylor-zenoah-baja-tsk-sx5-5t-5sc-exhaust-pipe
i also just noticed that @Barber213 's pipe has a 90 degree stinger as well ryan,A bit strange really, I saw the pipe you linked but figured the mounting was different to fit the tsk cage. Honestly in his situation I'd just hard mount it if it was me but in his case I'd find some heat resistant rubber and stick it in there. It just looks like that pipe was ment to fit a hybrid
I did notice Paul, either way I call it good in my book with the piece of rubber. @Barber213 I'd send it, you'll be good to go and I doubt there will be any vibration issues. Generally hard mounting pipes can cause the exhaust flange casting on the head to Crack.i also just noticed that @Barber213 's pipe has a 90 degree stinger as well ryan,
noth the ones i linked have less angle on the stinger, hopefully @Barber213 can tell us the exact pipe he has
agreed ryanI did notice Paul, either way I call it good in my book with the piece of rubber. @Barber213 I'd send it, you'll be good to go and I doubt there will be any vibration issues. Generally hard mounting pipes can cause the exhaust flange casting on the head to Crack.
I just did with pics . Thanks again .@Barber213 I definitely see it, strange tho that the rubber isolator doesn't fit properly. It's definitely clear as day on the outlaw/hybrid, for a curiosity send Mike Taylor an email and see what he says, he's extremely helpful and if it's not right in his eyes he definitely has superb customer service.
Thanks for the advice . I reached out to him and got the issue resolved . He told me to adjust the screws on the header and it fits perfect . Thanks again .look at the pics on taylor site fella, it shows the fitment with the bobbin ,
https://www.taylorrc.co.uk/product-page/rcmax-zenoah-baja-5b-side-pipe
