Shawnbrklyn
New Member
I have 30.5 cc runs great, But the other day I took off and it keeps bogging down. I thought it was the carb and bought a new one. Still the same thing, Could it be the clutch?
The compression is fine and the motor runs great. But when I take off it won't go. Thanks for the reply ?Could be a number of things. Compression still strong? When you replaced the carb did you check the manifold against a flat surface? They can warp and cause an air leak, even with a good gasket.
And BTW, welcome!
Ok thanks..If you can get us a short vid of this problem, we might be able to better assist in diagnosing. There are just a ton of variables to consider and we're poking around blindly without any kind of examples.
where did you find the settings? can you share them?Oh damn man, I had a car that didn't move for a month and it just needed some carb tuning. I found base recommended settings and went from there!
