Buggy Basher
- China
I want to put my MX43 Prolines on a Rovan Buggy. Anyone know what gears I would need to change to compensate for the much taller tires. Thanks.
Generally speaking if you were happy with the gearing performance with your original tires , when you swap out to larger diameter tires you will need to increase your final drive ratio.(larger tires will drop your rpms ) You do this by either swapping to a smaller tooth count clutch pinion gear, or increasing the tooth count on your driven spur gear. If you don't have any engine spacing adjustment , you have to buy a matched set of gears .I want to put my MX43 Prolines on a Rovan Buggy. Anyone know what gears I would need to change to compensate for the much taller tires. Thanks.
Thanks. I just bought new stock size tires and plan to leave it like it is. Dang thing is already too fast.Generally speaking if you were happy with the gearing performance with your original tires , when you swap out to larger diameter tires you will need to increase your final drive ratio.(larger tires will drop your rpms ) You do this by either swapping to a smaller tooth count clutch pinion gear, or increasing the tooth count on your driven spur gear. If you don't have any engine spacing adjustment , you have to buy a matched set of gears .
