HY32cc rebuild kit?
ZRC
Denton Texas
I've been searching for rebuild kit for my hy32cc with no luck. Found piston and ring but not wrist pin needle bearing and gasket set. Not sure if other parts are the same as smaller HY or other brands. Any help will be appreciated.
I bought Zenoah G320 piston, ring, and wrist pin needle bearing for my HY, they are totally different, much bigger.
HY is the stock Chinese engine in the Rampage. Part from CY or Zen would probably work tho. My engine has an RCMK crankcase, CY +2 crank and a Zenoah modded and ported head kit lol
Hybrid. ?
I replaced it w G320. Redcat is sending me a new motor and servos, warranty. Like to rebuild the damaged motor for spare.
Man, I need to take it easy w Loctite, had a hard time removing wheel nuts, super tight.
Installed new tires on my 5B, stock rear suck. Hope these have better traction.
Honestly the only thing I have ever used loctite on is the head bolts and the pinion gear. Never had a Bolt just vibrate loose
Lost 4 bolts on Rampage so far. I use Loctite on all bolts that go into metal thread and a little CA on plastic thread.
