Need to ask, why do you think you need a stiffer spring? That's been one of the most reliable, trouble free parts in my 5ive.
Have you tried tightening the spring first?
No there isn't a stiffer spring available that I know of. Power plant doesn't matter if it's a traction issue. It is an odd issue though and not a normal one for a 5ive to have. Are you certain you have the spring tightened correctly and nothing else is wrong? High traction is usually where issues like this happen. Going to a stiffer spring you may as well coil bind the current spring as you're going to be doing the same thing, putting a lot more strain on the steering components/ killing the servo saver action anyway.
AGFRC 78kg, 100kg and 125kg (16V). They've been ok so far.Just curious what servo are you using?
Already answered, no there's no aftermarket heavier spring. Whatever you're building that isn't a 5ive is your issue.
Thats strange, i run the same in my onroad 5ive and I too had to max out the compression of the servo saver. My issue was I had alot of grip, I'm finding it strange that your still having an issue. My only suggestion is go an aluminum style bellcrank and hope the bite is better. Your servo saver may just be tired and the mechanical friction is no longer there.
