tizdaz
- Sunny Northwest!
Hi guys, over the years I've always used a mesh or outwerwares to cover the flywheel and areas where debris etc could enter that could cause damage.
I've just purchased a Taylor Reed 35cc V2 and noticed that there is no big gap like on standard zen engines, but there are small holes instead for air flow, anyone here run shroud covers or mesh this area off on there reed cases, or do they not bother? if so what method did you use, I tried to fit my outerwares engine shroud from my zen 320 but its far too large for the reed case, so thinking what other option to use, on some of my older engines I silicone some mesh to cover the area, but was messy although did the trick, but on this reed engine I have I don't want to mess it up so looking for a solution that looks clean and does the job if needed
cheers!
cheers!
