Hello guys so I ended up installing a modified rc billet center diff mount and monster locker. Took it out for two runs but at the end of my second one it would slow down too fast as soon as I would get off the gas. Now I tried diagnosing what it was and noticed that when I let it go straight it would not bind up as much but a soon I turned left it something is binding and slows down I took out the motor and did the same I took the front center dog-bone out and rolled smooth then I put it back and removed the rear one and also rolled smoothly. The breaks are not resting on the rotors because I tried doing it with loose breaks. I wonder if could be the locker.
Forgot to mention that its when I turn left it binds up only when both dog bones are in.Hello guys so I ended up installing a modified rc billet center diff mount and monster locker. Took it out for two runs but at the end of my second one it would slow down too fast as soon as I would get off the gas. Now I tried diagnosing what it was and noticed that when I let it go straight it would not bind up as much but a soon I turned left it something is binding and slows down I took out the motor and did the same I took the front center dog-bone out and rolled smooth then I put it back and removed the rear one and also rolled smoothly. The breaks are not resting on the rotors because I tried doing it with loose breaks. I wonder if could be the locker.
