Kill switch not working
Ides28
hi i have a baja with the dynamite kill switch. it won't cut off the motor. it appears to work fine otherwise, can get the arming led to turn off when i adjust the third channel, will turn off if i turn off the transmitter. it just won't kill the motor lol, it'll start when the light isn't on. is the kill switch bad? everything else on the car works great.
I had a dynamite and it was a complete dud. Then was was given another and it works fine. Maybe you just lucked out like me. I've also read other people having similar problems with this k/switch.
So here's an observation why fault something that is working properly but not look at yourself for how you installed it? The answer is clear as day and i already said it. And for the dud yes I had one go on me gracefully but this scenario is the op's fault for not binding the radio system with the 3rd channel bound as a secondary fail safe. Depending on the radio your using which is the next question....which is?? And finally if you search I myself have wrote numerous times on how to properly bind the dynamite killswitch
I know it's an old post, but I have the same problem. Except it's a new install. Rovan 5sc flysky gt3b. Can turn the engine off by turning the tx off, but not with the 3rd channel. How do I properly bind the 3rd channel/ set secondary fail safe?
Thanks John
