Thank you. Currently, the adjustment has been successfully made and it is operational. The muffler was damaged so I replaced it with a dominator pipe. However, we are considering a more radical engine.The 45cc cheapo engines just run hot. You can mask with overly rich running, but at the end if the day you just need to make sure you're allowing it to cool. Or throw it out and get a better engine.
The setup is based on Taylor RC engine's 1107 carb setup.Good, you cab tell if an engine isn't getting enough fuel on the low speed if it's hard to start.
