LP40_FG
Reading the Rules!
Yes still no luck in getting the MCD started
so im going to strip the engine and go from there. Just woudering how can i clean the engine, piston, head crank etc.
Wash it out with petrol I did to mine got the grit out from the bottom of crankcase just make sure to wear some gloves petrol hurts your cuts even the ones you never new where there :lol:
Yeah and try to flush the bottom end out the petrol will go everywhere but should get it out if any is there and won't leave any residue behind do the same with the head, saves taking the whole bottom end apart and getting a new gasket set
Yeah give it a good shake about then have a look at it see if anything is still on it, the crankcase may leak a bit when you do it but you should see some crap come out if you have any in there just don't cover the patio in fuel (Like I didn't honest)![]()
Brake cleaner work pretty good too. I buy them when they go for $3 a can and stock up.
I even re-use the stuff to clean my air filters.
