dwarfy
- Rossendale
Just bought another marder off 1 of the guys over at the NWORCC forum with a view to tidying it up for my brother-in-law but might keep it as a project car!! From what I can see, spec is:
23cc engine with bling cover & DDM pullstart - not sure whether Zen or CY yet?
K&N style filter
FG tuned pipe
Alloy lower arms at back
Alloy upper arms at front with 1 No alloy lower arm
Alloy A & B front bulkhead parts
Alloy front hubs
FG alloy shocks (1 No with broken shaft)
Hitec steering servos
New spur, pinion & layshaft gears
Numerous std plastic items inc wishbones, fuel tank & suspension mounts
Spare set of 4 wheels with slicks
2 NIB slick tyres
Spare set of 4 wheels with spikes
Its far from perfect, the shell is broken in two, there is some damage to a front rose joint, radio tray is an ally home made affair -functional but doesn't look the best as is the receiver box, no radio gear (not a problem), no throttle servo, fuel tank leaks from filler cap.
Generally it just needs a good clean up & tidying. I have my beetle shell so rather than swapping mounts to use that shell I might use this car for it & keep both
It was a bit of a bargain I thought. Will get some pics posted when I get time this weekend & update the spec.
Will also take pics of the strip down & re-build
K&N style filter
FG tuned pipe
Alloy front hubs
2 NIB slick tyres
