dwarfy
it needs painting bud - looks like its going to sea :lol::lol:
Im lucky in the fact I have a compressor sat beside me in my workshop..all my r/c cars have had a blast down after each run and this one will be no different...
I'm desperate to get this out for a blast and see how much it will do but I guess I will have to make sure all is sorted before I take it out..
I have to order a kill switch but Not sure what to order as I know everybody says get a killer bee but I also know they don't work with my transmitter...ko propo espirit 2 on 40meg.. using this as I cant afford to go buy another tx at the moment..
so what other kill switches are out there? even if it don't work of a 3rd channel as long as it dies when required..i.e tranny goes off or battery disconects as I always run fail safes too..
Thats my engine fitted:w00t:
shocks rebuilt and fitted..:w00t:
Radio gear repaired
servo cables had been cut and twisted together instead of using a y cable.
now all soldered and heat shrunk
next will be set up the radio gear and drive.....
not taken any pics today but will have plenty tomorrow..WHEN ITS FINISHED:w00t::w00t::w00t::w00t:
Oh Did I mention the shell is also painted.....
Red and Yellow.. bit of white/blue and black...
It looks ok. not a really good finish but thats due to scraping the old paint off.
it will do me fine for bashing..
My 2nd marder has a battle switch which is a bigger version of the mod'd pico Ben has fitted. Not tried it so cant comment on how it operates but they are supposed to be ok
seen it workin fella when the young lad had it at deeside so you shouldn't have any probs![]()
great job on the mesh mod and sorry i misunderstood about the gap, few washers will fix that, have the same problem with my elcon set up.
what kind of adhesive did you use?
