wezg
I have been busy in the workshop this afternoon as I had a spare hour or so.
My baja is now in bits and requires a lot of tlc to get it back to a good standard
I found a few horrors and a few things are now clearer...:no:
So far I want to replace all of the screws and bolts throughout the car i don't think FG designed this using wood screws..!!!
Half of the bearings are a bit gritty or tight so all will be replaced
the diff has a tooth missing and there was a couple of cable ties in place of a rear brace..
found out that was due to the engine being sat in the wrong place and the brace no longer fitted...there were some broken bolts in the alloy engine mounts and they had been redrilled to fit back into the car..:w00t:
they have now been removed...the joys of red locktite so the engine should now sit back in the correct place
have a few pics....
As it was when I got it
The missing brakes must be hiding with the missing brace
The car as it sits just now(hope to get the suspension stripped tonight)
All the spare that came with it..
Hopefully I will get a chance to strip the rest down and make up a list of things to order...
have a few pics....
