46u
I have a 5b SS now and like it a lot but miss 4 wheel drive and when I see my way fit would like to get the RR V4 Competition. I use to race 1/8 buggies and 4 wheel drive handles so much better then 2 wheel drive. Been doing some research and this looks like about the best deal for the money.
Are there any up grades you recommend or is it a fairly stable platform? I have been looking at some of the parts and up grades. Does it come with big bore shocks or is this something that needs to be up graded? I notice it does not come with a center dif is this something else that needs to be up graded? All my 1/8 scales had center diff. I have seen where some recommend the Alloy Engine Carrier Plate is this a necessary up grade?
It uses dual steering servos does it take large scale servos or standard size? I think large scale. Do you have to run dual servos? I have 4 engines so I would get it with out an engine so save on a little money. Is this all ready built of come as a kit? If it comes some what assembled do the do a good job at the factory or is it like so many others where you need to redo it and make sure all the metal to metal fasteners have loctite on them?
Any recommendations and input will greatly be appreciated. THANKS!
