Anyone with steel gears for 2 speed ?
cougar2465
Sydney
Hi
Thinking of getting steel gears (pinion and spurs) for my 2 speed from Big Boys Toys. Anyone has experience with these steel gears? suggestions? reviews?
Cheers
Hi, I don't know if there are steel gears (spurs) for 2 speed, but you can ask for someone with the right equipment to make them.
I use steel gear (1 speed only) and it works really good, the only problem it's the noise made by them.
cheers
Nope, from day one I switched to alloy. Never regretted it. I would say the only thing I needed to watch was that my grubs didn't come loose and the gear spin. Filing the grub flat and using locktight solved all the problems.
Hi
Cheers
If you buy these let me know and we can go halves in the shipping as I would love a set of those also.
ok, I emailed big boys toy but they only had steel 44t instock. Do you know anyone else who stock them? i'll need 44t, 46t and 48t.. let me know.
If they still are, check with your distributor? :phone:
AUSTRALIA
Grenenger Enterprises PTY LTD.
Imp. & Distrib./A.C.N. 058 138 426
17 Timberland Road
AT-4505 Burpengary QLD
Tel. 0061-754286700
Fax 0061-754286711
e-mail: [email protected]
They are distributor for FG and FG don't make stell gear for 2 speed.
Anyother place you know of I can get alloy gears for 2 speed?
Cheers
hey BTB I have the firehammer and I would like to know if or what I NEED TO GET FOR THE TWO speed trans can you send me a pm on what I need to do I havea 8000 rpm clutch with a jet pro pipe .spectrum DX-3.and now I just bought the swamp kong tiresI am building the axel extenders now what else can I do to it ..I think it just needs two gears I plan to put a DDM motor in it soon please let me know thanks
I believe you only need to change out the gear plate and large motor mount to FG. The two speed should have the rest. With the power you had better upgrade the diff cage if you haven't already. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUB2&P=PU
Here are the available FG 2 speed gears and numbers: http://j.b5z.net/i/u/2162054/i/2_Speed_7451_Off_Road_Manual.jpg
Here is a photo of a FireHammer with 2 speed.:cool2:
No prob...
You will notice in the last photo the person fitted the FG alloy uprights to take out some of the flex on the rear end. Since this is not the MT you will have less flex from the smaller tires, but the only real way to remove completely the flex is to upgrade the rear lower arms to alloy and you could also install the risers to move the upright rod higher away from the gears. Here is a photo of the rear of an FGMB/FG buggy with this setup I am not sure if the risers work with a 2 speed though? You should be ok with the buggy though it is a bigger problem with the FGMT and the bigger tires.
Here is the rear arm flex I'm talking about, gets worse the older the arms get on the MT. You will see the flex toward the gear allowed by the plastic lower arms.
http://media.putfile.com/Rear-arm-flex
