did you read the desription
I wouldnt call it a clone it has more aftermarket parts and hpi parts on it then it does km. you obvioulsly are new at 1/5 scale.
and if your so hung up the clone stigma why are you in the km forum
I would bet money if the km part was left out of the add you wouldnt be able to tell the deiffernce.
thats a 2000+ car if you tried to get it all HPI.. so what it has km chassis and hub carriers.
if you bought an ss you wouls still have a weak car. and eventually put most if not all of those upgrades on it. its a better car that what you get for 1600.00 on an hpi. 1600.00 for an HPI brand new and you wouldnt half the upgrades that has
and if you buy a km youll end up the same result upgrades.
why pay more? for the same thing.
that car is probably the most durable car your going to find for sale if you know what your looking at.
Zenoah G290 (28.5) 4 bolt motor
walbaro
990 carb
zenoah cluch housing
Zenoah clutch w/8000 rpm spring
Proline desparado wheels front and rear
proline badlands rear tires
HPI front dirt buster ribs
HPI roll cage
HPI center roll bar
HPI billit clutch carrier
HPI shock towers
HPI wing
HPI SS Aluminumcase all meatal gear Differential
FLM Hardened Drive and diferential cups
FLM 9mm dogbone with replacable pins
RPM fronr upper and lower a arm
RPM rear upper and lower a arms
Turtle Racing HD top plate (front)
Turtle Racing HD tranny plate
turtle Racing v2 Rear shock tower mount v2
Turtle Racing Front shock mounnt/combo mount
KM 1 in. axle entenders
KM Tuned Pipe
KM Chassis
KM wheel carriers Front and rear
KM Bulkheads Front and rear
KM Fuel tank and battery box
KM VVC shocks with HD 6mm shafts
