new-fg-owner
hey guys took the car out for a really good run today about 45mins. trouble is think i've set my car up totally wrong was insane as soon as i put the power down the car would just spin out and then once it picked up speed on the straight it would do like two 360 spins. i've losened off the lsd made some difference, now the place i ran it was quite dusty and had loads of grit down from where it had snowed month before!!
furthermore when i had it on full power and turned the wheels the back would just push the car forward without any turn very bizare!?
My setup is as follows, ride height front 16mm rear 18mm front camber neg 1 degree back neg 2 degrees with two degrees of toe in on the rear and one degree toe out on the front! i have the spings very stiff so i dunno if im just running the whole car to stiff? thanks guys any help on if its setup bad or just bad survice thanks
