motor is a 29cc that it come with, carb too, never changed the carb, where needles are at, lost count, but i started with the standard start off for LS and HS, and adjusted from there.
basically, in easier terms to understand, i just adjusted needles to a good smooth running engine, and added just a hair more OUT turn on needles once ideal spots were found. somewhere round 1/32 to 1/16 more, all it does is add a tiddy bit more fuel/oil mainly for lube reasons on engine
it took me a lil bit to get HS adjusted, as i did not do the lift rear and letter rip method, thats one way, i don't like to do, or the run it and stop adjust method, which i prefer.
