Diff removal
Nope, definitely going the right direction. There were a few screws in this truck that were a bear to get out. Thanks man.
lol i have had many problems with a lot of my screws..it seems almost every screw was lock tighted down:rolleyes:..i just ended up taking my time and doing what other people mentioned and heated them and then replaced them all with tony's screws
I've been replacing the screws with stainless ones as I go. The cost about $1 a piece, so I'm thinking about getting the rcscrews kit as it will be cheaper in the long run :)
I'm on their website right now. Should i download a BAJA SS manual so that I'll know what to order? The KM manual doesn't tell screw sizes.
DUMB QUESTION:: Is an M4x15mm the same as a 4mmx15mm on the bolt depot website? Im looking at a Baja SS manual and they mention all the bolts as M4, M5, M6 and so on.
your looking at the metric,all M-type screws are standard course thread so M4x 12MM , M5x12MM etc. is what you want 4mm 5mm etc thats what they have on there site you wont an cant get the wrong type on there unless your looking at the standard screws and not the metric highlighted in the pink area on the lower left of the screen
Well, I added up every screw from the manual and with shipping I'm at $41. Theres an RCScrewz kit on Ebay for $45 shipping/inc, so I might just order that.
you gotta away with $41? man i spent $370 on every screw size and then some because when you add or upgrade theres more screws, but most common your gonna use is the 5x12 and the 5x16
Maybe I screwed up, no pun intended :) I just looked at the Baja SS parts list in the manual and stated adding them to my cart. I know that I had well over 100 screws in my cart.
2 baja's, but i changed out every screw and then some of the upgrades have different size screws, rpm bumpers requires some screws a bit longer screws and the drag pipes use another size, as well as the chassis kits i used had different sizes, i have used possibly 250 in screws already, i'm sure i will use alot more i had the mounting screws to my drag pipes the threaded end must of hit a rock or stone at one point and had to replace those 4 times already
