what parts are needed to change back to the buggy thanks ?
are you able to keep the double shock set up, might be a good idea as they are not the best out there. you will obviously need the front section of the roll cage, plastic side pods, the front shock tower is different but i guess you get the other one with the 4wd kit. as for wheels you say you like the buggy version ,if you cant find any fg baja wheels or marder wheels then the older mcd wheels fit upto the rr v3 and smartech,xtm, carson wheels fit also.I like the stepstuds tyres better then the fg nobblies but they seem a little too grippy at times and thats not good for the 'grip roll' , also there are 3rd party bodys too,ill see if i can dig some up.
I guess you prefer the buggy better, you say its lighter and more nimble, even loosing those big mt5 wheels and using the fg marder/baja wheels frees up performance killed by the weight of those things.
good luck with the conversion
