SELWA
- Milton,On CANADA
I'm really liking your style! Where you get the body panels?
What wheels/tires are those?
Is there anyway u can take a pic of these tires holding the stock tires to compare. Trying to figure out how much beefier these tires are or narrow....?
Thanks!
I sold off my old tires but they were bigger. I can measure these up and you can compare that way.
6 5/8"x 2 5/8"
All the HPI wheels and tires will fit, but with the stock body on the rears will rub a bit so you need the adapters,only on the rear other wise fronts are fine,i ran baja 5t fronts all the way around on mine,but if you do get adapters,wouldnt recomend the verdigo had one round out on me pretty bad when your plastic proline wheel is stronger then the alum.used on there adapters..Thanks. You know if we can use HPI wheels/tires combo without any other mods on our Losi 5's?
