PAUL931
hi guys
have new engine never seen spot of fuel YET..
best way to run in please ?
cheers paul
cheers paul
This question comes up so often on these forums and most of the time I find the responses funny / unusual.
Let me ask a few questions of my own first.
When you buy a new lawn mower, how do you run it in?
When you buy a new leaf blower or weedwacker, how do you run it in?
When you buy a new chain saw, how do you run it in?
What about a petrol generator or pressure cleaner..... how do you run them in?
The short answer is "you don't".
1:1 scale car engines in the past had a rough cross hatch / honed finish in the bore and they needed to be run in gently.
Some nitro engines use tapperd pistons / bores that require a gentle break in period also.
Our engines have an average surface finish in the bore that is chrome plated and the piston has only one ring on them.
When you start up a brand new engine you need to take it easy so it can get to normal operating temperature..... this applies to any engine new or old.
Providing your oil ratio is as per the manufacturers spec and your carb settings are correct you simply drive the wheels off the thing.
I try to avoid long wide open throttle periods for the first hour and avoid running out of fuel as starving the engine of fuel also starves the engine of lubrication.
All my engines are run in while I'm racing them on the track.
FYI, 4 of my engines finished in the top 3 podium positions over 4 classes at the recent Australian titles and they were broken in at the track.
