tizdaz
- Sunny Northwest!
Hi guys
bought a new large alloy engine mount for my FG monster as my old one the bolt had snapped inside the hole (as you can see in pic)
the new one came, fitted it (or tried to!) but when i went to fix the brace plate the hole in the engine mount is about 5mm off, i know it don't sound alot, but ive moved my engine as far back as possible due to the mesh with the diff gear so cant move it back no more, ive also made the hole bigger in the brace plate but its still off by about 2-3mm
As you can see in pics the hole is clearly not center as it should be, i contacted the seller & sent pics but replied by saying hes compared it to an original FG mount he has & the hole is in same place (which is not true), so i quickly googled a few images which ive posted below, the hole should 100% be in the center..
the seller did say i can return it which im going to, but i need a large mount asap! i don't have a tap & dye set or i would have just tried to fix my old one
Anyone that knows about the engine brace on FG's know that theres VERY little room for error when fitting it, 2-3mm is all it takes to completely knock the gear mesh out, as it is with this engine mount, i cant even get the bolt to go in properly, if i tried to screw the bolt in, it would end up going in on a n angle probably stripping the thread!
new mount on the left & my old mount on right with snapped bolt inside! doh:
& heres a pic off the net clearly showing hole in middle even on the original FG mount:
Now im thinking should i ask for a refund or replacement?
If i get a refund should i buy a tap & dye set instead? what i don't wanna do is buy & tap & dye set to try fix my old one only to bodge it up more as ive never used one before & i don't wanna be left in the same position if i do bodge it up, which will mean im going to have to spend more money on a new mount! ?
