Wierd squeal sound on Losi DBXL
DBXLGUY
Getting a weird squeal sound when I give the DBXL gas and it will hardly move. I took the wheels off of the ground and gave it full throttle and no squeal. Any ideas?
Thinking two cycle oil may have leaked from a broken seal at the exhaust and gotten onto the clutch causing clutch to slip. Possible?
Clutch slipping?
Need more info... How many tanks run? Any modification to driveline or lager motor?
Only mod was the exhaust but that was a while ago. After the squeal I noticed the seal from the exhaust to the head has broken causing oil/gas to leak out. Thinking now that it nave leaked onto the clutch causing it to slip. Possible?
Your broke you have a bearing going bad look around check drive shafts and there pins
I will double check the pins. Would the bad bearings cause the car to hardly move while giving the car full throttle?
There is a drive pin broken if it barley moves or wheel is lose sorry if mistakes on typing don't have glasses on check rear diff gear ill bet case is melted look for bearing sticking out of case
What do you mean the wheel is lose? What wheel? Thanks.
Wheel loose could mean that any wheel could be loose enough to allow the hex to slip inside the rim. Often stripping out the plastic rims hex
1. Do the wheels spin freely by hand?
2. Does the truck move easy by pushing it, if not center diff might have a rock or something jamming it
May have to start at the spur gear and turn it by hand while holding each of the driveshafts, front center, rear center, front left, front right, etc. feeling for something slipping.
Check the rear half shaft, Its hard to see but in between the motor and servo I had those set screws come loose lost power to the rear
